So this morning started fresh and was hopefull the analysis would be succesfull for a change, and started another attempt which is currently running (i hope).
When changing back to the HUB the following message showed:
Since then i can not enter our HUB and therefor can not use the program!?
S.O.S. ... Help?
Update: Seems to work again, i could login into our HUB
Hey,
Sorry that you had this issue this morning.. We have made the appropriate changes and everything should be working now.
Please let me know, if you are still facing this issue
Best,
Samarvir singh
Hi Samarvir,
A few minutes after my post i could login again, so it seems to work again, thanks for the fast repair!
