Hi!
You need to first place the buildings into your proposal and then select the buildings you would like to rotate before choosing "rotate" in the tool menu.
Hope that helped.
Arne
Thank you for the response. However, is it possible to rotate multiple instances from the library all at once after placing them? Currently, it's not possible to rotate library instances while placing them, only after they've been placed.
It would be really helpful to be able to rotate multiple placed buildings simultaneously, especially when aligning them to a project's grid, as rotating each one individually is quite time-consuming.
