Rhino Forma Plugin error
pircit
Observer Observer
pircit
Observer
Observer
While I was previously able to run "forma" normally via Rhino, I am now getting this error and my form panel is not working.
caoimhe_loftus
Sorry to hear you are having issues with the Forma Rhino plug-in - please can you confirm which version of Rhino and the plug-in you are using? You can see the most recent updates to the rhino plug-in here, note there are some recent required updates.
dimitar.venkovRR6E3
Hi, did you install any other plugins prior to the error?
pircit
Observer
Observer
İ used rhino forma extension and my rhino version is rhino 8
pircit
Observer
Observer
Yes i installed datasmith for unreal engine 5 after that i get error i gues
dimitar.venkovRR6E3
Hi Talha, can you try the following:
- go to `Window > Containers` and uncheck Forma
- restart Rhino
- go to `Window > Containers` and check Forma again
