Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
MUA
2 REPLIES 2
Adrian5D
291 Views, 2 Replies
MUA
Adrian5D
Whats your hottest tip for showing and or calculating MUA (as its called in Norway) on a site?๐Ÿ˜Ž
MUA
Labels (2)
2 REPLIES 2
magnhild.gjestvang
Hi! Symetri is a company that is working on building a MUA extension(add-in) to Forma. The extension is in closed beta and under testing by several users. If you want to test it out, you can apply here! Hope that this will serve your need ๐Ÿ™‚
Best regards, Magnhild
Adrian5D
Thanks, I'll give them a try. ๐Ÿ˜‰
(Perhaps it will be implementet when the tech is ready, I'm sucker for everything that's in one "box"..)
