Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Géolocalisation, ifc, revit, dwg, géomètre, surveyor
8 REPLIES 8
Message 1 of 9
p_deon
995 Views, 8 Replies
When I export a 3D land from Spacemaker to Revit, it doesn’t overlap properly with its plot plan from cadastre.data.gouv. Yet the two files are geolocalized and we have control over the data.
I have a similar issue when I try to overlap a 3D land with a land surveyor land.
I am enclosing the method I used and the screenshots that show the lag I noticed.
Please let me know whether you have a solution to this situation, or the instructions on how to gather land registry or land surveyor land to the geometry from spacemaker.
I used the following two methods:
1st method:
  • In Revit, open IFC file, which converts it into a Revit file whose basis point is set to integrate geo tracking.
  • Insert the land registry DWG file with option Origin set to origin.
  • I noticed a 124-meter gap on an axis. Yet the IFC was generated with the CC9-zones option and Zones 9 choice.
2nd method:
  • In Revit, generate a blank file.
  • Insert the IFC (it arrives above the basis point).
  • Insert the land registry DWG (option center to center).
  • Select the DWG, import the coordinates. I noticed that the basis point has detached from the original point. The file is geotracked.
  • Select the IFC and in plan, manually move so that it overlaps with the land registry.
The first method doesn’t work, and the second one calls for a manual opération which leads to mistakes.
Please let me know whether there is a more efficient method.
Thank you in advance
et maintenant Pour les francophones,
Bonjour à tous,
Lorsque j'exporte un terrain en 3d depuis Spacemaker vers Revit, celui-ci ne se superpose pas correctement avec son plan parcellaire issue de cadastre.data.gouv. Pourtant les deux fichiers sont géolocalisés et nous avons la main sur les référentiels.
J'ai le même problème si je souhaite superposer 3d d'un terrain avec un plan de géomètre.
Je joins à ce message la méthode employée et les captures d'écran montrant le décalage observé.
Si vous avez une solution à ce problème de superposition ou bien une marche à suivre pour compiler cadastre ou plan de géomètre avec des géométries issues de spacemaker, je suis preneur.
De mon côté, j'avais essayé deux méthodes:
1ere méthode
-Dans revit, ouvrir le fichier ifc, cela le convertit en fichier revit dont le point de base est placé pour intégrer la géolocalisation.
-Insérer le fichier dwg du cadastre avec option Origine à origine.
-On constate un  écart de 124m sur un axe. Pourtant l’ifc à été généré avec l’option CC9zones et choix de la zones 9.
2ème méthode
-Dans revit créer un fichier vierge
-Insérer l’ifc (celui-ci arrive au dessus du point de base)
-Insérer le dwg du cadastre (option centre à centre)
-sélectionner le dwg, importer les coordonnées. On constate que le point de base s’est détaché du point d’origine. Le fichier est géolocalisé.
-Sélectionner l’ifc et en plan le bouger « à la main » pour qu’il se superpose avec le cadastre.
La 1ère méthode ne fonctionne pas et la seconde nécessite une opération « à la main » ce qui est source d’erreur. s’il y a une méthode plus efficace je suis très intéressé.
Je vous remercie
Paul Déon
ATAUB ARCHITECTES
Labels (4)
8 REPLIES 8
Message 2 of 9
trygve_aaberge
in reply to: p_deon
Hi, sorry for the late answer. I'm not sure why this problem occurs, could you send us the IFC and DWG files so we can check? It might be best to contact us in Intercom (the contact support link in the product) and send the files there.
Trygve Aaberge
Software Engineer
Message 3 of 9
p_deon
in reply to: trygve_aaberge
thank you.
You will find the files here.
Paul Déon
Message 4 of 9
trygve_aaberge
in reply to: p_deon
Hi again, and sorry for the long delay. I tried to take a look at this, but I haven't figured out why it's incorrect in Revit unfortunately. I see that you didn't upload the IFC files you exported from Spacemaker, only the Revit files. However, I created a project in the same location and exported the IFC file, and I see the same issue with placement in relation to the DWG file as you get.
I checked both the IFC and DWG file, and I see that they contain coordinates in the same location, and they both get placed at the correct location when importing into Spacemaker (after converting the DWG to DXF with AutoCAD, since we don't support DWG). I don't know why it's incorrect in Revit, but I have asked someone with more knowledge about Revit, so hopefully I can get back to you with more info.
Trygve Aaberge
Software Engineer
Message 5 of 9
p_deon
thank you for your time.
I have tried with the ifc file and the revit file from spacemaker and I have the same issue with the both ways;
I hope your coworker will find a solution
Message 6 of 9
Hi @p_deon,
Did you find a solution? After reviewing the conversation, I have the impression that the problem is in Revit, not Spacemaker. Am I right?
Best regards,
Daniel
Message 7 of 9
I didn't find any solution. You're right, you need to open revit to see the problem but maybe Spacemaker is guilty.
thanks
Message 8 of 9
p_deon
in reply to: p_deon
Bonjour à tous
j’ai enfin fait des captures vidéo (voir lien wetransfer ci-dessous) de mes problèmes de superpositions des 3d des terrains générées depuis forma avec un plan de géomètre dwg importé dans Revit.
J’ai fait l’essai avec plusieurs sites et à chaque fois j’ai des écarts compris entre 200 & 250m.
Dans les vidéos ci-joint:
0-Création Site depuis forma
1-Récupération cadastre dxf. (le cadastre disponible depuis cadastr.data.gouv est géolocalisé. Aussi je l’ai téléchargé en dxf pour montrer sur autocad que la superposition fonctionne bien entre le cadastre et le plan topo du géomètre. Au préalable, il faut s’assurer que le plan topo est bien en CC 9 zones.)
2-Superposition géomètre & cadastre. La superposition fonctionne bien. Il y a juste un coef d’echelle x100 à prévoir pour l’import du cadastre.
3-Import plan géomètre. Dans cette vidéo, j’importe le plan topo dans Revit afin de géolocaliser mon fichier Revit
4-Import forma dans Revit.  Utilisation du plugin d’import de Forma dans Revit. La 3d forma est convertie en surface topographique revit.
5-Ecart géomètre forma. La 3d forma est complétée sur forma pour avoir les bâtiments, ce qui permet de prendre une côte vers le plan topo. Un écart de plus de 200m est observé.
(vidéos ci-dessous et dans message suivants)
Pouvez-vous m’indiquer à quelle étape je me trompe ?
Je vous remercie
Paul Déon
Message 9 of 9
p_deon
in reply to: p_deon
second post pour suite et fin des vidéos.
