I was testing the board feature and I imported a shadow sequence that I created with forma. However upon selecting 7 images, forma brought them in by some order that was unknown. So I had to either delete them all and add then in a controlled manner, 1 or 2 at a time, or reference the images in windows explorer/second monitor and make the sequence in forma match.
My request is if forma could recognize some kind of sequence and import those in that order.
In my example, the sequence was named after the hour of the day (automatically by the shadow add-in/plugin), so it was 08-00.png, 10-00.png,12-00.png, etc.
Part of this feature request is also a way to see the name of the image that was imported. When I am in the board, I have no way to see in some sort of list, the images that are added to this board, but I also have no way to see the name of the file, so that in my example, I can order the images by the sequence name in the file name.
Thanks.
Thanks.
Solved by samarvir_singh_bhayana. Go to Solution.
Thanks for the input @javier_oropeza-TAG ! We really appreciate you taking the rim. The feedback is understood and noted 🙂
