Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Export to Revit
33 REPLIES 33
Message 1 of 34
BIMadmin
1226 Views, 33 Replies
Export to Revit
BIMadmin
I have noted when exporting masses from Forma to Revit some masses jump randomly, it happens with the same masses in different proposals! what is going on with the exporter? and how long is going to be a beta?
Export to Revit
Labels (2)
33 REPLIES 33
Message 2 of 34
F.Garcia6Y866
in reply to: BIMadmin
F.Garcia6Y866
I have spotted 3 but I am sure there are more.
Message 3 of 34
BIMadmin
in reply to: F.Garcia6Y866
BIMadmin
another one
another one
Message 4 of 34
smilksh
smilksh
@BIMadmin @F.Garcia6Y866 We are sorry to hear you are having trouble with the Forma <> Revit integration.
When you say this happens in multiple proposals, are the buildings you are seeing issues with in the proposals, or in the base?
The easiest way for us to trouble shoot this would be to access your Forma project directly.
If you are comfortable sharing your project URL with our development team, you can send it to me in a Private Message and we will see if we can find the problem.
You will see the Beta question addressed near the top of our Help documentation, found here:
https://help.autodeskforma.com/en/articles/6984724-revit-interoperability
Here to help,
-Heather from Forma
Here to help,
-Heather from Forma
Message 5 of 34
F.Garcia6Y866
in reply to: smilksh
F.Garcia6Y866
Private message where? Give me your details.
It happens with basic buildings modelled in the proposals not in base.
Message 6 of 34
smilksh
smilksh
@F.Garcia6Y866 Thank you for the response, I will reach out directly.
-Heather from Forma
-Heather from Forma
Message 7 of 34
F.Garcia6Y866
F.Garcia6Y866
Hey guys,
Sorry but the Forma to Revit Exporter is a joke!!! it does not work, it makes so many major mistakes.
Please take a look at the differences!!!!
Hey guys,
Message 8 of 34
smilksh
smilksh
@F.Garcia6Y866 - We can see what you are showing us but we cannot investigate without the project you are using.
I have sent you a direct message after our last exchange to which you can reply with your project URL and we will take a look at what is going on.
We are sorry for your frustration but sometimes we need data to investigate.
-Heather from Forma
-Heather from Forma
Message 9 of 34
F.Garcia6Y866
F.Garcia6Y866
Hi Smilksh,
You should be able to investigate this already as I sent you the link on the 25/07/24 and follow by an email asking for answers but no reply whatsoever.
what is even more frustating is when I try to create a technical support case and I found out that Forma is unsupported.
Nevermind I will keep trying and I will send you the link again.
Regards
Hi Smilksh,
Regards
Message 10 of 34
F.Garcia6Y866
F.Garcia6Y866
This is the project url:
"deleting the url from here just keep it on private"
You can try exporting Option 1 Massing
In our end we are using Revit 2022 and the latest Forma Addin.
Message 11 of 34
F.Garcia6Y866
F.Garcia6Y866
In a way to shortage the issue, we have found out that the problem happens when exporting masses, when using walls, floors and roofs is fine.
so if you only export masses, with the below settings is when it fails
Message 12 of 34
greg_marr
greg_marr
Thanks for the update.  I had started to look at it yesterday but had been unable to reproduce it.  I was hoping to get back to it today.  This will make it easier.
Message 13 of 34
BIMadmin
in reply to: greg_marr
BIMadmin
How long do we need to wait to get answer on this?
Message 14 of 34
smilksh
smilksh
Apologies for the gap in communication.
We were able to find data we were missing and are currently working on the fix.
We will let you know when the fix is available.
-Heather from Forma
-Heather from Forma
Message 15 of 34
F.Garcia6Y866
F.Garcia6Y866
Morning Heather, is this sorted? by the way can you please! also copy the fuction into the mass floor when you fix the code?
Message 16 of 34
F.Garcia6Y866
any update on this fix?
Message 17 of 34
greg_marr
greg_marr
The function should now be available on mass floors, this is a server-side fix.  We are working on a release of the add-in for the positioning fix.
Message 18 of 34
F.Garcia6Y866
F.Garcia6Y866
Hello Greg,
Can you be more specific please?
I have tested it in:
Existing Mass in Current Proposal.
New Mass in Current Proposal.
New Mass in New Proposal.
But I dont get the Usage Values.
I am working in Revit 2022.
Is this the parameter that should store the data?
Hello Greg,
Message 19 of 34
greg_marr
greg_marr
Sorry, looks like I misunderstood a status report.  I thought that the server-side change was enough to resolve this issue.  We are still working on this.
Message 20 of 34
F.Garcia6Y866
F.Garcia6Y866
I see, can you please give us a timeframe when this will be fixed please?
