building are above the ground
manoranjan_athokpam
manoranjan_athokpam
josh.goldstein
Hi @manoranjan_athokpam,
Our apologies, and thanks for letting us know.
Were the buildings and the satellite image ordered through Forma, or were they imported by you?
If the buildings came from Forma, can you let us know which data source you used?
Josh Goldstein
Senior Product Manager
manoranjan_athokpam
>From the forma itself
hallvard.braatenE6H3T
Hello @manoranjan_athokpam, in which country is the project located?
manoranjan_athokpam
Prato, italy
This can happen if you change terrain after adding the buildings to the proposal. This should be fixed if you remove the buildings and add them again.
simon.irgensZ22TS
I hope the above solution worked for you. Let us know if your terrain is still causing you trouble. Or feel free to take it through our Help function direction from Forma.
Best, Simon
