Unable to update rhino element to forma
914648984
914648984
When I transfer a Rhino volume to the Forma platform, an error always appears. I just uploaded a very simple volume. Why is this?
kasper.herlov
Hi, sorry you are having issues. It also seems like a quite weird issue. Which version of Rhino are you running here?
-Kasper from Forma
I've tried using Rhino 8.1, 8.13, 8.2, 7.15, and 7.29, and even changed computers. The Forma plug-in window appears empty when I open it in 7.15 and 7.29. I can open Forma in 8.1, 8.13, and 8.2, and successfully import objects from Forma to Rhino, but I can't upload Rhino objects to Forma. I'm using the Forma Plug-in for Rhino v0.7.15. Could you help me find a solution? I need it urgently!
kasper.herlov
Sorry for the trouble. I think we will basically need your file to test on our end. Are you able to share the file on a link with me and send in a DM here on the forum?
This problem still exists. The model is just a simple block and cannot be uploaded to Forma, but the terrain can be downloaded from Forma
dimitar.venkovRR6E3
Hi, thank you very much for sharing the model and your project details. We looked into the logs and found the following error:
由于连接方在一段时间后没有正确答复或连接的主机没有反应,连接尝试失败 (The connection attempt failed because the other party did not respond properly after a period of time or the host did not respond.)
Would it be possible to check with your IT that outgoing connections to "https://app.autodeskforma.com/", particularly from the "Rhino.exe" process, are not blocked by a firewall rule? Alternatively, would it be possible to try uploading to Forma from a different internet connection?
