Move multiple lines in floorplan sketch
kevin_fielding
kevin_fielding
The floorplan sketching function has improved significantly since I last tested it, however it appears you are still unable to select and move multiple lines at the same time.
I would suggest that this is activity that will be undertaken often.
In this example I want to move all the selected lines in one action, this doesn't appear possible. Selecting and moving the lines individually is unnecessarily laborious.
I'm happy to be corrected if the functionality exists.
arne.bjelland
First of all I would like to thank you for multiple posts with detailed description of what you would like to achieve! It really helps our team to understand how we could drive value for our user.
Regarding your question about moving multiple lines at the same time, the answer is unfortunately that it is not possible at the moment. This functionality is defiantly something we would like to support, but I am not able to be more concrete about when it will be released.
Regards.
Arne
william_cooper
Any development on this? It’s very frustrating that is is not fixed since 2024
