Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Remove Project Files Folder
Give users ability to remove the Project Files folder or get rid of it all together. This folder does not provide any additional value and unnecessarily extends the file path through Desktop Connector. Removing it would help reduce path lengths and make it easier for users to manage the Windows 260-character limit.
2 Comments
caldwell_eEGT6H
I strongly support this idea. I regularly run into file path length issues while using Forma files.
david_gonzalezJYUXV
I might be wrong, but I guess that other tools in Forma have hidden folders. If project admins can't view/edit "Project Files", as permision; we wouldn't be able to run any reports. Actually I would vouch for surfacing those hidden folders like attachments and so on. If Autodesk "Removes" Project Files we would end up with limited permissions inside.
On the other hand, to reduce the risk with path lenghts. I would suggest better description tooltips. All users should access folder descriptions on the website, desktop connector and exports. Maybe hovering over each folder, even if they can not access all content inside.    What do you think for a Naming convention for folders similar to the compliance tools that Autodesk has for files?  So admins can enforce better naming convention for files and folders. In my humble opinion, people tend to add more folders when they actually need more metadata instead. Most of the time, creating packages and parsing those files; solves those subfolder requirements. Any folder that you can think of, is metadata, is a label for the files inside. If users editing folders could create subfolder from a list which names has a prestablished code and a multiline text description. They can arrange team files in a way that suits them.
