Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Project Template Settings - Schedule, Assets, Sheets, Correspondence
We have created a project template for our company to use for all new projects in Autodesk.
There are a number of settings, permissions and templates that can only be setup after the new project has been created. This becomes a very time consuming process with the number of projects we are creating.
The following updates would be great to see and edit at a project template level in Autodesk Build:
  • Schedule
    • adding roles to schedule permissions
    • creating plan templates (currently this can only be done within each project, but you still have to manually build the plan each time first)
  • Assets
    • adding roles to permissions
  • Enabling collections in sheets
  • Correspondence
    • creating correspondence types
5 Comments
j_feeke
I have mentioned this already mulitple times to succes managers from Autodeks, but it doesnt seem te get through, and new policy is to add "feature requests" throught the idea board.
Why are things developed for projects instead of project templates. Basicaly a template is also a project, but one that gets copied when a new project is created based on that template.
We turn 200+ projects a year and because new features that are developed are only available on projects and not in templates all those things (i.e. correspondence types, create 4 correspondence types in 200 projects, means doing the same thing 800 times!) need to be implemented on each new project instead of setting them up in the template.
It should be a lot easier to devolop for the templates as that would surely make it also availble for a seperate project. Main time saver.
Also, it seems that once it's developed for projects, there is less interest to expand it to templates (as it takes forever for a new feature to reach a template, if it makes it at all)
Making things that can be configured in a project also available in a template is the missing link. It's the thing that would make a nice product a great product.
matt.docter
Add Specifications to this list as well!
James_Bippes
We get frustrated requests for this all the time - including Specifications. Adding this would prevent clients from looking elsewhere.
mwolfeAKBWD
We would like to arrange all ACC Build Tools Permissions settings in our project templates to standardize our projects. In particular, we are currently in need of the settings / permissions for the Schedule tool, however it is not available in the template and all settings and permissions need to be adjusted on a project-basis. This does not allow for an efficient use of project setup as they cannot be templatized.  According to other idea postings, many other tools don't have this functionality either such as Assets, Specifications, or  Meetings.
Tags (3)
jonminick
Duplicate ideas were merged into this one. Their votes and comments now count here, so please keep voting on this idea.
