Problem
In Forma Data Management, Naming Conventions can currently only be configured after a project has been created. There is no option to define a Naming Convention at the Hub Admin level and have it automatically applied to designated folders when new projects are created.
This creates unnecessary manual work, particularly in environments where many projects are created and where project creation is automated.
The Naming Convention should be active from the moment the relevant project folders become available, before any files are uploaded.
Challenges / Consequences
Suggested Improvement
Allow administrators to configure Naming Conventions at the Hub level in the project template, so that the Naming Convention is automatically enabled and configured when a new project is created.
Expected Benefit
Hub-level configuration would reduce manual administration, improve consistency across projects, and make Naming Conventions much more suitable for automated project creation workflows. It would also reduce the risk of projects being created without the required file-naming controls.
