Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Manually Edit Cost Markups on Change Orders
The project setting to calculate the change order's markups by percent would remain but in some case scenarios, the markups for one change order need to be edited manually. This may be due to an agreement with the owner on the markup values for that particular change order. The system should allow the ability to click on the markup value and edit it in the same way it allows changes to the values of the other lines.
3 Comments
krystal_burton
Adding that it would be nice when the "variable" is toggled on in the markup settings that we could change the amount or the % either in the pop up menu when it's applied or in the grid.
ian_turner
Hello, can you not use the 'variable' markup setting available in markup settings which is for this purpose?
krystal_burton
We do have that turned on, however, that only allows us to adjust to a percentage and not a dollar value. Often times we need to override the dollar amount and currently it makes us try to figure out the percent to be able to do that. If we could override on the grid in the PCO then that would also solve our issue.
