ACC Template with Workshared Revit models - Autodesk Community
Doubling down on the previous post above.
With the ability to create projects from a true templatized ACC setup, the next most useful update would be to either bring back being able to Publish Coordinates to cloud models.
OR
Have the ability to see all models Internal, Project, and Survey Base Points and be able to adjust them globally within ACC (maybe from within Insight/Design?) When Coordinating (or if a project location moves) there is no simple way to locate, adjust, the models when you have 9+ links. Or if everything is setup correct and someone moves a Base point and it doesn't get immediately caught can have real consequences.
OR
Having both options, using Revit to publish coordinates from 1 model with all links (and those links don't need the main coordinating model loaded in their model). Utilizing Insight so that if/when something becomes uncoordinated it can send an automated email.
