Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Enable Custom Attributes on Folders in ACC Docs
Summary
Currently, Autodesk Construction Cloud (ACC) allows metadata and attributes to be applied primarily at the file level, while folders do not support structured custom attributes.
For teams managing large volumes of documents, we strongly request the ability to assign custom, typed attributes to folders and use them for search and filtering, similar to enterprise document management systems.
Background & Use Case
Many project teams are transitioning from other document management platforms to ACC Docs while maintaining parallel operations during migration.
In these environments:
  • Folders represent meaningful project groupings (e.g., project units, delivery stages, organizational structures)
  • Users need to search and filter folders based on structured information, not free text
  • Folder-level attributes are essential to replicate existing, well-established document management rules
Current Limitation
At present, folders can only store unstructured information (e.g., notes or annotations), which creates several issues:
  • No ability to define data types (date, dropdown, text, etc.)
  • High risk of:
    • Inconsistent input
    • Typos
    • Users ignoring input rules
  • Difficult to enforce governance and standardized operations
Workarounds such as encoding information into folder names or annotations are possible, but they are not scalable, error-prone, and hard to maintain.
Required Attribute Examples (Illustrative)
Typical folder-level attributes required include:
  • Organizational category (dropdown)
  • Completion or milestone date (date field)
  • Department or functional group (dropdown or text field)
These attributes need:
  • Controlled input (data type enforcement)
  • Consistent values
  • Searchability across the folder structure
Business Impact
Without structured folder attributes, teams are forced to:
  • Overcomplicate folder hierarchies
  • Rely on naming conventions instead of data
  • Accept reduced search accuracy compared to existing enterprise platforms
This creates friction during platform adoption and limits ACC’s effectiveness as a centralized document management solution for large projects.
Requested Enhancement
  • Enable custom attributes on folders in ACC Docs
  • Support typed fields (date, dropdown, text, etc.)
  • Allow folders to be searchable and filterable based on these attributes
  • Apply governance rules similar to file-level metadata
Expected Benefits
  • Improves document discoverability at scale
  • Reduces operational errors caused by free-text input
  • Eases migration from existing document management systems
  • Strengthens ACC Docs as an enterprise-ready platform
This enhancement would significantly improve usability for teams managing complex document structures and align ACC Docs with real-world enterprise document management needs.
Thank you for your consideration.
2 Comments
三好康平
We request the ability to view linked deliverable items for specific files (drawings, etc.) within Docs using custom fields or similar functionality.
Ideally, this would include a setting to "display deliverables linked to referenced items," allowing users to navigate directly from drawings to their associated deliverable items.
Currently it is also not possible to edit system attribute "Description" via the "Edit attributes value" function. Also you can´t select it in the "Extract pages and attribute" tool.
If you want to modify the description for files you need to click on each file in the description row and edit it for each single file.
As a work around we have added a custom attribute "Title" which is accessible via above mentioned tool. With that we are able to batch edit this attribute.
A disadvantage of this work around is that we still require the "Description" attribute which is currently only available to name folders / give them a description / title.
Also the description is automatically used in many tools like packages & transmittals. And in some of the tools we can´t add our custome attribute "Title" instead of using the empty "Description" attribute.
Highly appreciate if the description attribute would be also editable via "Edit attributes value" and "Extract pages and attributes" tool.
Also appreciate if custom attributes could be used for folders
