Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Edit Project Information Programmatically
While developing some in house solutions for project closeouts in ACC, I ran into a fairly large roadblock. There doesn't seem to be a way to PATCH a project like there is in BIM360 from the API (the only PATCH there is for ACC is for uploading a project image). The goal being, have the ability to change project status from active to archived via the API.
Now this isn't a deal breaker as there are some roundabout ways to get similar results, however I find it strange that the option to change project information post creation doesn't exist in the ACC API, minus the ability to upload an image.
It would be great to have the ability to update/change certain project properties post creation via the API, as this functionality seems to be available in the older BIM360 platform.
6 Comments
I agree. In our company we create the Project early on while still in the Sales phase. Sales reps don't tend to name the projects at that time in the greatest way so when getting the actual order and putting creating the project in our ERP we get the actual project name. Then it's not possible for us to update the name.
We also have the above-mentioned problem with archiving.
nrossLZ5XJ
Agreed. I can't imagine why this functionality has been left out of their API.
@ltucker22VY7 what is the workaround you references to get similar results? I have been trying to come up with something but haven't had much luck.
ltucker22VY7
@nrossLZ5XJ In the case of pseudo-closing/archiving a project, since we couldn't change the status, one thing we did was programmatically remove all users from a project when we were marking it as completed so no more changes could be made before we could send someone in to manually change the project status to 'archive' in ACC.
Now this isn't a huge revelation, but for the meantime it's suited us. Hoping that sometime soon we will get the ability to change project properties through the API.
wim_de_winter
If a project’s name, address, or project type changes, we want to update the Forma project’s metadata via the API. The Admin API does not have an endpoint for this (only PATCH …/projects/{projectId}/image).
Could you also provide endpoints to update the name, address, project type, and other metadata via the API?
Thanks.
Tags (3)
jonminick
Duplicate ideas were merged into this one. Their votes and comments now count here, so please keep voting on this idea.
a_clarke
Autodesk, could you please clarify the status of basic project update functionality in Forma/ACC? The BIM 360 API previously supported project renaming via PATCH /projects/:project_id, but this endpoint is documented as incompatible with ACC (now FORMA) projects and appears to no longer be available in the current workflow.
This is a significant loss of functionality, and it would be helpful to know whether this is an intentional change or a bug, as well as what the expected replacement behavior is.
