Project Image Settings
bhollowayTC8PP
bhollowayTC8PP
Was the ability to replace the default project image with our own removed? I went into the setting tab today and the project image option is gone from settings.
atighe84
Hi @bhollowayTC8PP
When you go to 'Project Admin' of the project in question and then go to 'Settings', then select 'Edit', do you see the option to choose a file for the project image as per the screenshots shared below? You should be able to add the project thumbnail here.
Andrew
