Desktop Connector 16.13
hubbardFJXGT
Message 1 of 12
hubbardFJXGT
After updating to 16.13 DC is not starting on its own and keeps stopping without any warning or error dialog.
Anyone else having this issue? Want to make sure its stable before rolling out to the rest of the teams
Replies (11)
Message 2 of 12
RSomppi
Did you uninstall the previous version? If so, that could be the problem.
Message 3 of 12
hubbardFJXGT
No, I just preformed the update. Only remove if there is a true problem. It went fine and started back up on its own on Fri. and worked all day. But today it did not start on Windows startup and has stopped twice after starting manually.
I am going to try a reboot in a bit and see if it starts on its own again.
Message 4 of 12
RSomppi
I just installed the update this morning without issue. It reinitiated on it's own after the update and restarted with a reboot of the machine.
Message 5 of 12
RSomppi
I'm starting to see similar issues. Do you have anything more on this?
Message 6 of 12
hubbardFJXGT
it seems to be staying running, but is not starting on its own after reboot or startup.
Message 7 of 12
RSomppi
Did you check your startup apps list?
Message 8 of 12
hubbardFJXGT
yeah its in there
Message 9 of 12
hubbardFJXGT
So yesterday DC started normally and stayed running all day.
Today it did not start and then quit shortly after starting. Manually restarted it and so far its staying.
Message 10 of 12
RSomppi
I ended up reinstalling because I couldn't take the time to troubleshoot.
Message 11 of 12
hubbardFJXGT
has that fixed it?
Did you fully remove and reinstall?
Message 12 of 12
RSomppi
Yes and yes.
