Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Adding sheet table with sheet set palette (Insert tables but not showing sheets)
cyberflow
Advisor Advisor
Message 1 of 15
cyberflow
Hi all,
I've been trying to insert a table but without succes :
The list of sheet doesnt get populated inside the table, the table header shows :
The sheet set is on ACC and was started with the ACC web workflow but we've switched onto classic ssm to insert the table
We tried to see if that works on another sheetset and yes :
Anyone has an idea on what is happening ?
LinkedIn  - Frank Freitas - CAE/CAD/BIM Coordinator & Support Specialist
Autodesk Civil 3D Certified Professional
Replies (14)
Message 2 of 15
cyberflow
Morning all, anyone has a clue or exeperienced this ?
Message 3 of 15
catherine.watson
Hi @cyberflow, I'm sorry to hear your experiencing this issue. To start us troubleshooting, could you please answer the questions below:
  • While in AutoCAD, could you please type "ABOUT" and share a screenshot of the About dialogue box that comes up?
  • I understand the issue is only occurring with this one sheet set, is that correct?
  • Is the sheet set table list not displaying in multiple drawings or only one?
  • Does this happen on multiple machines and with multiple users, or only one?
  • When did this issue start?
Thank you and I look forward to hearing from you!
Catherine Watson
Technical Support Specialist
Message 4 of 15
jreidKVSUZ
Cyber Flow,
Can you select the ones you want to be brought into your drawing individually?  VS coming off the main project name?
As shown in the pasted image below.
Here is a post I did last week on SSM. Maybe this will give you a deeper skill set to get what you need.
https://forums.autodesk.com/t5/autocad-forum/i-want-to-include-the-layout-name-in-the-sheet-list-tab...
Hope this helps!!
Thanks, JRR!
Message 5 of 15
catherine.watson
Hi @cyberflow, Checking in here, do you still need assistance with this issue?
Catherine Watson
Message 6 of 15
cyberflow
Hi @catherine.watson forgot to reply on your post
We're runinng 2025 in production
Yes correct, this happens only with sheetset done on the ACC
Only the header of the table is showing, not the content
Happens with everyone in the company
Issue started a few times ago, cant ping an exact time but pretty sure it was functionnal in 2024
Any news or feedback from development or support team ?
Message 7 of 15
cyberflow
Hi @jreidKVSUZ
Thanx for replying, i did try that and it has the same behavior if the sheetset is on ACC
Message 8 of 15
jreidKVSUZ
Cyber Flow,
Can you copy all the files needed for you SSM into your Download folder.
Can strip them of all your perinate information and then zip the files and let us see the setup first hand?
You'd only need to do two or three and then maybe someone could help your company out.
Also, can you post an image of the exact way you want your drawing index to appear. I am sure you have manually corrected the issue. It'd be nice to see one in the correct format you need.
Hope this helps!
Thanks, JRR!
Message 9 of 15
cyberflow
Hi @jreidKVSUZ
Unfortunatly i can't share that since there's confidential information related to the project.
And i do think there's a related point with ACC on the server side
Message 10 of 15
jreidKVSUZ
Cyber Flow,
Can you send the DST file?
We can review that and make our own files to match your callouts.
Thanks, JRR!
Message 11 of 15
cyberflow
Hi everyone,
I wanted to share an update based on my discussions with Autodesk Support:
  • Case Escalation: My case has been escalated to the Civil 3D development team for triage.
  • Potential Cause: The issue might be related to layout indexing in the .dst file. Refreshing the index could help. One suggested workaround is pulling the .dst from ACC and re-adding the files locally. Another idea is moving affected layouts to a new subset and then back.
  • Workarounds Discussed:
    • Avoid copying and editing .dst files; create new ones when needed.
    • Ensure unsupported fonts aren’t being used.
    • Consider using a regular table with text fields linked to Sheet Set Manager properties (though setup and maintenance take more time).
    • Try moving sheets to a local location and re-uploading them.
    • Test different Civil 3D versions to see if the issue persists.
  • Fix Timeline: If a code fix is required, it will likely take months. In the meantime, finding a workaround that works for your team is recommended.
  • Future Changes: There’s a chance that upcoming changes to Sheet Set Manager and its ACC integration (expected in Civil 3D 2026.2) could resolve this issue but for sure in the future 2027 this will be resolved.
If anyone has tried similar workarounds or has other ideas, I’d love to hear your feedback.
Message 12 of 15
jreidKVSUZ
Cyber Flow,
Thanks for sharing. I have not had any issues with SSM except working on SharePoint, but  figured that issue out by always making sure to login to SharePoint before opening AutoCAD.
With that all said, did their fix / suggestion help your concerns?
Thanks, JRR!
Message 13 of 15
cyberflow
We're going to move forward with an inhouse programmed command that will insert the table as per our standards
Gona avoid some clicks and speed up our users work
Message 14 of 15
jreidKVSUZ
Cyber Flow,
Glad you found a solution. Would you be able to share that "inhouse programmed command" with us all? or how it functions.
Thanks, JRR!
Message 15 of 15
catherine.watson
Hi @cyberflow, Thank you for the update! I am glad you and the Civil 3D team have figured out a customized command that works for your team. Any details you can share about this solution are super helpful.
Catherine Watson
