Two new bugs when loading .OBJ files and when running analysis
lauren_chapmanQUXBD
Message 1 of 1
lauren_chapmanQUXBD
1. When I import an .obj it isn't letting me see the import parameters screen to change the import dimensions settings. Instead it loads straight into the library, and when I try to go back to import parameters, it just shows the import file screen again. So I can't change my import settings from m to mm.
2. I am also experiencing bugs when I run an analysis. For example, I get a notice from forma saying "An analysis with this configuration already exists", and it takes me to see the previously run assessment, which is a deleted assessment, which I deleted as I have since fixed some faces in the geometry. However the analysis doesn't show up in the analysis history, and this notice means it won't let me re-run the analysis.
Replies (0)
