Add geometry via the API -
Michel_van_Geel_DAQS
Is there any more information / documentation I can look at on how to create Geometry via the API? The current available info is a bit sparse:
https://aps.autodesk.com/en/docs/forma/v1/reference/http-reference/geometries-batchcreategeometries-...
My goal is to let the user add default buildings to the model (via the Forma UI). Or is there a better way to do that?
Michel
havard.hoiby
With that API you can add GeoJSON (Polygons, Line) from a server/backend, or you can do GLB with Integrate
If you want to add stuff from a browser, I would suggest building a JS extension using our SDK. The docs for the SDK contains more usage examples.
Getting started: https://aps.autodesk.com/en/docs/forma/v1/embedded-views/introduction/
Examples:
https://app.autodeskforma.com/forma-embedded-view-sdk/docs/classes/geodata.GeoDataApi.html
https://app.autodeskforma.com/forma-embedded-view-sdk/docs/classes/elements.FloorStackApi.html
https://app.autodeskforma.com/forma-embedded-view-sdk/docs/interfaces/integrate-elements.CreateEleme...
-Håvard
