How do i setup tsconfig.json and tsconfig.app.json of an Angular app using 'forma-embedded-view-sdk/auto'
iklimis
iklimis
Hi
I trying to build a forma extension using Angular 16 and the  "forma-embedded-view-sdk" library.
I am running in a lot of issues regarding the tsconfig setup.
Is there a working example of an Angular app that uses the library with correct import and correct tsconfig setup
It would be tremendous help
henrik_steenJL382
Hello!
The current package is distributed as a EcmaScript Module (ESM) with multiple package entry points.
In order for TypeScript to load this you need to set "moduleResolution" to "Node16" or "NodeNext", as well as switching your code to ESM by setting "type" to "module" in your package.json.
More details here:
https://www.typescriptlang.org/docs/handbook/esm-node.html
https://www.typescriptlang.org/tsconfig#moduleResolution
Note that when writing ESM modules you need to include the (final, e.g. .js) file extension in imports from your own project, so you'll likely get lots of errors until you've done that too.
Hope this helps!
iklimis
Hello  henrik_steenJL382!
thanks for your reply
I have already added "type": "module" in package.json and also used "moduleResolution": "NodeNext" in compilerOptions. Although the forma-sdk is now imported without errors there problem now is that (although my code compiles) I get errors like the following which is basic import statements in a typical angular module/component .
My imports now seem not to be recognized.
Also could you elaborate on how to add the extension in I presume angular.json?
henrik_steenJL382
The error you are showing is the missing file extension names in the import path. You'll have to add ".js". But it seems that using ESM entirely with Angular is not stable yet, so you might see some errors on various cases (like the local server). See https://angular.io/guide/esbuild for details.
We've modified our forma-embedded-view-sdk package so you should now be able to install it without modifying your moduleResolution or setting type=module. Please try it out instead (minimum version of forma-embedded-view-sdk must be 0.14.1) and let us know if this solves your problems.
Henrik
iklimis
Thank you very much! Works great now!
