Hello Forma Team!!
hope you all doing great,
So the need arose in our business model where we need to save a terrain image that our user has downloaded through our extension as a Library item in order for the user to be able to use the image outside of the extension if they choose to.
I have already experimented with gld files that can get uploaded as a library items but have not yet how to do the same with a jpg or png file..
Can you share your thoughts or advice on how to approach this issue??
Thanks a lot
Giannis
Solved by kristoffer.dyrkorn. Go to Solution.
Hi!
We are currently working on changing the systems involved to make this possible. Unfortunately we cannot share a timeline of when it will be available.
Best regards,
Kristoffer
Autodesk Forma
@kristoffer.dyrkorn
Thanks for your reply
Would u be able to provide an alternative workaround on how to create an Image Library item?
Hi!
Unfortunately we do not have a workaround available for this use case. The capability we are working on is the way we will solve that need (store raster data in Library through the SDK).
Best regards,
Kristoffer
Autodesk Forma
