Forma API: Render line in 3d scene
paul_knokeMRKMH
paul_knokeMRKMH
I was wondering How I render a line created via Forma API. This is my code:
async function App() {
  const line = await Forma.designTool.getLine();
In Forma I can then create a new line but when I hit enter to complete the creation the line disappears.
I guess I need to somehow render this line in the scene but I havent figuered out a way to do this.
havard.hoiby
Hi Paul.
There is no simple way to render a line in the API now.
The APIs you used under 'Forma.designTool' is intended for you to request the user to draw some geometry, that you will then use inside your extension. It will use the built in UI in Forma to do so, and will return the drawn line as geometry to the extension as showed in the example here
To render this line into the scene you have a few options. You can either create an element. This is used when you intend for the line to be persisted into the proposal the user is looking at, and affect analyses. For this you can either user the FloorStack or Integrate apis to first create an element and then the Proposal api to add this element to the scene. I do believe that the Integrate API accepts a Geojson structure and in this you should be able to pass LineStrings.
Another option is to use the Render API. Either the Mesh or the GLB version. But neither of these make it very convenient to add lines. We do have a plan for a Geojson version which would make it easier to render lines onto the terrain.
I hope these pointers helps you in figuring this out, further than that I would love to hear what you intend to use this for so I could see what APIs that might be most suited, or learn what APIs are currently missing for your use case 🙂 Feel free to elaborate on your use case in this thread.
paul_knokeMRKMH
Hey Harvard,
I appreciate your suggestions. I will try it using a Geojson. At the moment, I don't have a particular use case in mind, rather I'm trying to get more familar with the forma api.
jose_loaiza5W6L6
Hello, guys I need something similar, I need to create a polygons or lines in 3d scene but I don't want use the desingTool, I only want to pass some coordinates and draw. do you have any suggestions.
Thank you so much
havard.hoiby
For anyone landing on this issue, the option I mentioned above with a Geojson API is now available.
See the docs here: https://app.autodeskforma.com/forma-embedded-view-sdk/docs/classes/render.RenderGeojsonApi.html
Here is a simple example:
import { Forma } from "forma-embedded-view-sdk/auto"
await Forma.render.geojson.add({
  geojson: {
    type: "FeatureCollection",
    features: [
        type: "Feature",
        properties: {},
        geometry: {
          type: "LineString",
          coordinates: [
            [-100, -100],
            [100, 100],
