Revit Insight Carbon results not changing between insulation scenarios
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hope you’re doing well. I’m a beginner Revit user and I’m doing a small research study using Revit Insight Carbon for an LPPS (large-panel prefabricated apartment) building.
My goal is to compare:
- Baseline (existing wall)
- Three retrofit options: PIR 100 mm, XPS 100 mm, and Mineral Wool 100 mm
Issue: After I change the wall types/material layers for the three insulation cases, the Insight Carbon results stay the same (the outputs look identical across PIR/XPS/Mineral Wool). I only see a difference between Baseline vs Retrofit, but not between the three insulation materials.
What I changed/checked:
- Created separate wall types and edited the wall assembly layers (added 100 mm insulation layer).
- Tried changing the analytic construction (Schematic Types / Conceptual Types) and rerunning.
- Checked Energy Settings / Advanced Energy Settings (Detailed Elements on/off, etc.).
- Re-synced/ran simulations again, but still the three insulation scenarios show the same carbon results.
Could you please advise what I might be missing? For example:
- Is Insight Carbon using a generic insulation dataset so PIR/XPS/Mineral Wool end up the same unless I map them to different EPD/manufacturer data?
- Do I need to change something in Material Thermal Properties / Schematic Types so that each insulation type is recognized as a different material for embodied carbon?
- Is there a recommended workflow to make sure the model updates correctly (e.g., clearing old runs, duplicating views/models, checking which elements are counted, or verifying material takeoffs)?
If it helps, I can share screenshots of my wall assemblies and the Insight Carbon dashboard outputs.
Thank you very much for your time and support.
Best regards,
