Error: Issue: An error has occurred related to the DOE-2 simulation
Message 1 of 17
After trying to get a energy analysis I receiveproblem2.JPG this email. Any help?
Replies (16)
Message 2 of 17
krishnan.gowri
Please refer to the two situations and solutions in the link below for possible causes of the issue you are encountering:
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-9F244D1F-8EEA-4DAE-97E2-DF5312B66589
If this does not resolve your problem, let us know.
Krishnan Gowri, Ph.D. FASHRAE, LEED AP
Principal Engineer
Generative Design Group
Message 3 of 17
I'm using Revit 2016 and I've got this error.
Wahat can I do?
Thank you,
best reguards
Francesca
Message 4 of 17
krishnan.gowri
This error is caused by envelope wall constructions having more than 10 layers.  You can either remove unnecessary duplication of layers in the construction or override the construction using generic types with matching thermal properties.  Please see the options in the "Energy Settings", advanced options, material thermal properties.  Alternatively, you can uncheck the "Detailed Elements" option and use Insight factor widgets to set the envelope thermal properties.
Principal Engineer
Message 5 of 17
Thank you for your help. The situation now seems better but not solved.
errore GBS 2.pngHow can I identify the LAYERS aim0231 and aim0266 in my model?
Cordially
Francesca
Message 6 of 17
mstein7484
Unfortunately the layers are often automatically given names by Insight are not used in the Revit model.
I can try to help find the construction names for you. Please do the following to help us investigate the problem:
  1. Log into Green Building Studio https://gbs.autodesk.com with your Autodesk account (Green Building Studio is the analysis engine used by Insight 360)
  2. You will be taken to the Projects page
  3. Click on the Project associated with the failed analysis
  4. You will be taken to the Runs List page
  5. Open the Actions menu and select Export the run list to Excel
  6. You can reply to me in a personal message with the Runs List file attached
Marjorie Stein
QA Analyst
[email protected]
Message 7 of 17
Hi!
I've quite the same problem with my model.
I cannot get the results, because my  analysis was failed.
Did anyone have sth simmilar?
Message 8 of 17
mstein7484
Hi @Anonymous
The error indicates that at least four of the construction elements in your Revit model have thermal property values for conductivity that are not within reasonable ranges. Review the conductivity values and edit them as necessary.
Alternatively you can perform the Insight analysis using default constructions in your model by deselecting "Detailed Elements" in the Insight Energy Settings > Advanced. See the Material Thermal Properties section of this Help Topic for more information: Advanced Energy Settings
Let us know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
Marjorie Stein
QA Analyst
[email protected]
Message 9 of 17
DanGarnier
I'm having a similar error, but it doesn't mention conductivity or another element.
Thank you,
Message 10 of 17
Hi I cannot resole this issue, despite following the troubleshooting recommendations.
Message 11 of 17
It seems that the values of the coordinates are very high. Try to move your building to the origin of coordinates.
Regards
José Regueira
Message 12 of 17
2846394415
Hi Sir
I have a similar problem and please see attached pic. Would someone tell me what is  the mean of that?
Many Thanks!
Message 13 of 17
I also found similar problem but after your post I solve my issue thanks for this. scholarsband
Message 14 of 17
jackfleming11.2.2
Community Visitor
Community Visitor
This blunder is brought about by envelope divider developments having in excess of 10 layers. You can either eliminate pointless duplication of layers in the development or supersede the development by utilizing nonexclusive sorts with matching warm properties. If it's not too much trouble, see the choices in the "Energy Settings", "Progressive Choices," and "Material Warm Properties." On the other hand, you can uncheck the "Point [by] Point Elements" choice and use the Insight factor gadgets to set the envelope warm properties.
On the other hand, you can play out the Insight examination involving default developments in your model by deselecting "Definite Elements" in the Insight Energy Settings > Advanced. See the Material Thermal Properties part of this help topic for more data: Advanced Energy Settings
In any case, please acknowledge this as an answer so that others can benefit from the information.
Message 15 of 17
e.m.usman13
Hi same problem i am getting. Did you got any solution?
Message 16 of 17
gokcen.ezgi.sen
Hello @e.m.usman13 ,
I think you might want to check out another forum discussion on the issue;
Analysis Failed
Best regards,
Gokcen Ezgi Sen
MSc. Architect - BIM Consultant
LinkedIn
Message 17 of 17
benmaamermariem
Community Visitor
Community Visitor
i keep receiving this failed message again and again, although i didn't modify anything, it worked previously!!!
