- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
My name is Malcolm, I am doing a project for Bach.Eng.Tech. (civil) at ARA Institute in Christchurch NZ.
I am trying to determine the baseline of results, i.e. the parameters/metrics that the analysis uses to determine the results.
I have modeled a large structure 120m x 45m, an animal shelter with a hydroponic tunnel house on top, a hybrid structure for agriculture.
I have set the location and picked a weather station, got results from within Revit and out of Carbon Insight. However what I am really after is what the internal environment is as a starting point that these results are calculated from. Clearly the analysis uses the weather stats to determine what this environment internally is through out the year, and that is the information I want to see. Is there any way of accessing these background metrics.
Also can you adjust the parameters used by the analysis. e.g. heating set point, cooling set point as these are aimed at human comfort levels not that of animals in the shelter, which will probably not be controlled and will be open to the surrounding environment.
The project is a bit left field of the normal use of Revit and building performance analysis as it is aimed at a sustainability and food production productivity study, However these are the tools I have used before and wanted to utilise in the study, I did the original BPAC cert from back in the this day of GreenBuilding studio. I am also going to undertake some modeling in CFD also as part of the study.
Any pointers gratefully received.
Regards
Malcolm
