Advancement in Processes & Post Processing, Solvers, Hydrodynamics.
I wish this software be more advance with following factors: (& am confident that this will be in coming Future)
It should address prediction of processes involving Fluid flow, Heat & Mass Transfer, Chemical Reaction & Combustion. This will use laws of physics i.e. Conservation of mass, momentum, energy.
Post processing should include Velocity, Pressure, areas of Turbulence (Reynolds Number), Lift & Drag, Vector Plot, Contour Plot, Streamlines & iso-surfaces. 3D Vector results should be available.
Not only Aerodynamic but also Hydrodynamics should be available. It will work not only on stationary objects but also on moving objects (So that real life scenarios can be analyzed).
Please hit Kudos if you also agree with this.
