Hi!
I'm a student of University of Genoa; when I try to install Flow design on my PC the installation fails.
The first time the installation log file was this:
2017/3/3:12:28:54 Nicolò NICOLÒ-HP === Setup started on NICOLÒ-HP by Nicolò ===
2017/3/3:12:28:54 Nicolò NICOLÒ-HP Path_Length: 147
2017/3/3:12:28:54 Nicolò NICOLÒ-HP Current Directory C:\Autodesk\Flow_Design_2014_English_WIN_64bit_R3_dlm
2017/3/3:12:28:54 Nicolò NICOLÒ-HP Launch
2017/3/3:12:28:54 Nicolò NICOLÒ-HP CommandLine
2017/3/3:12:28:54 Nicolò NICOLÒ-HP Current Directory C:\Users\NICOL~1\AppData\Local\Temp\_AIC080.tmp
2017/3/3:12:28:56 Nicolò NICOLÒ-HP === Setup ended ===
2017/3/3:12:28:55 Nicolò NICOLÒ-HP === Setup started on NICOLÒ-HP by Nicolò ===
2017/3/3:12:28:55 Nicolò NICOLÒ-HP Path_Length: 147
2017/3/3:12:28:55 Nicolò NICOLÒ-HP Current Directory C:\Users\NICOL~1\AppData\Local\Temp\_AIC080.tmp
2017/3/3:12:28:55 Nicolò NICOLÒ-HP Launch
2017/3/3:12:28:56 Nicolò NICOLÒ-HP PageOpen LaunchDialog
2017/3/3:12:29:01 Nicolò NICOLÒ-HP PageOpen LicenseDialog
2017/3/3:12:29:05 Nicolò NICOLÒ-HP PageOpen ProductSelectionDialog2
2017/3/3:12:29:10 Nicolò NICOLÒ-HP PageOpen FullProgressDialog
2017/3/3:12:29:10 Nicolò NICOLÒ-HP Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Flow_Design_2014_English_WIN_64bit_R3_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /q /norestart
2017/3/3:12:29:11 Nicolò NICOLÒ-HP Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1603
Then I try to solve the problem using this article:
but the installation fails again and this is the log file:
2017/3/3:12:39:37 Nicolò NICOLÒ-HP === Setup started on NICOLÒ-HP by Nicolò ===
2017/3/3:12:39:37 Nicolò NICOLÒ-HP Path_Length: 147
2017/3/3:12:39:37 Nicolò NICOLÒ-HP Current Directory C:\Autodesk\Flow_Design_2014_English_WIN_64bit_R3_dlm
2017/3/3:12:39:37 Nicolò NICOLÒ-HP Launch
2017/3/3:12:39:37 Nicolò NICOLÒ-HP CommandLine
2017/3/3:12:39:37 Nicolò NICOLÒ-HP Current Directory C:\Users\NICOL~1\AppData\Local\Temp\_AI9180.tmp
2017/3/3:12:39:38 Nicolò NICOLÒ-HP === Setup ended ===
2017/3/3:12:39:38 Nicolò NICOLÒ-HP === Setup started on NICOLÒ-HP by Nicolò ===
2017/3/3:12:39:38 Nicolò NICOLÒ-HP Path_Length: 147
2017/3/3:12:39:38 Nicolò NICOLÒ-HP Current Directory C:\Users\NICOL~1\AppData\Local\Temp\_AI9180.tmp
2017/3/3:12:39:38 Nicolò NICOLÒ-HP Launch
2017/3/3:12:39:38 Nicolò NICOLÒ-HP PageOpen LaunchDialog
2017/3/3:12:39:41 Nicolò NICOLÒ-HP PageOpen LicenseDialog
2017/3/3:12:39:43 Nicolò NICOLÒ-HP PageOpen ProductSelectionDialog2
2017/3/3:12:39:44 Nicolò NICOLÒ-HP PageOpen FullProgressDialog
2017/3/3:12:39:44 Nicolò NICOLÒ-HP Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Flow_Design_2014_English_WIN_64bit_R3_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /q /norestart
2017/3/3:12:39:56 Nicolò NICOLÒ-HP Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1603
What can I do?
Thanks for the answers!
