Flow design cannot read my models
RaydenAmeer
RaydenAmeer
So i downloaded the flow design free software
And also i downloaded the inventor to create my f1 car
But there is no flow design on the environment tab as stated in many tutorials, I already uninstall flow design and installed it back but i still recieve the same result
I manually import the file in flow design but it only read it as a sphere
hartogj
Hi Rayden
Can you let us know which version of Inventor you are using (2014, 2015) and whether or not it is Inventor Professional? Also let us know which Operating System you are using. Flow Design is supported on Inventor Professional 2014 / 2015 on 64 bit versions of Win 7 and Win 8.
Also, please attach the file you are using for the manual import into Flow Design standalone so we can investigate it here. In the meantime I would suggest using an STL format if you haven't tried that already as a workaround.
Jon
Jon den Hartog
Product Manager
RaydenAmeer
Thank you for the reply, My standalone flow design manage to read it in stl version, Thank you.
