[Account not authorized] Your autodesk account...
Message 1 of 44
I just recently got a 3 year student license for Autodesk Flow. But...when I run the program I am prompted with: "Your autodesk account is not entitled for flow design" Has any one had this problem? If so how do you fix it? I have read a few threads about this and nothing has helped. I contacted customer support and they said they cant offer help to student licenses...
-Thanks.
Replies (43)
Message 2 of 44
hartogj
Accounts can take some time to be updated when services are added. There have been some cases where it has taken a day. Are you still seeing the issue? Do you see Flow Design listed as an available download in the accounts portal (accounts.autodesk.com) or in the additional downloads located in subscription center?
Jon
Jon den Hartog
Product Manager
Message 3 of 44
I created a new account and that solved the problem. Thank you for the help though 🙂
Message 4 of 44
Is there any REAL explanation for what is going on here?  I am having the same problem:  All worked well the first time I installed the program, 24hrs later this...
All I see is moderators apologizing for the inconvenience but not really offering a real solution or explanation.
Message 5 of 44
Quick question. I'm doing the project with Flow for class. Signed up two days ago as a student, with two seperate emails. There was a day difference for email registrations and even now when I try to get in it says unauthorized. Any ideas how I can get in?
Message 6 of 44
jessica.t
Hi @Anonymous and welcome to the Autodesk Community!
For any issues you are experiencing with your Education Community account, please contact the education team directly by filling out this problem form.
Thank you!
Jessica Thrasher
Message 7 of 44
Hi, I faced the same problem by not being able to use the flow design because i cannot access the account. Could you please advise on the steps to solve this problem?
Message 8 of 44
camilo.lemos
As described on Jessica's post above yours, please contact the education team directly by filling out this problem form.
I hope this helps!
Camilo Lemos
Message 9 of 44
pv
I have the exact same problem, I purchased the standalone version. (Not education license)
It shows up in my Autodesk Account, i have downloaded and installed the software and when I attempt to use it I get the message "Your Autodesk Account is not entitled for Flow Design."
I have waited a day and still no results. I purchased this software to use in a project with deadlines. The fact I have paid for software and cant use it is ridiculous!
I have even submitted a case file to try and get it resolved.. no response yet.
Case ID: 10691773
Message 10 of 44
camilo.lemos
Hi @pv and welcome to the Autodesk Community!
I sincerely apologize for the trouble and inconvenience.
I've asked the customer service team to prioritize your support case, they will get back to you via email as soon as possible.
I hope this helps!
Camilo Lemos
Message 11 of 44
It's good to know I'm not the only one experiencing this specific issue. I
hope they can work out a solution soon, I don't have the time to waste
waiting for it to work, with deadlines so close.​
Message 12 of 44
Hi, I have the same problem, really confusing.... detail:
Order Number: 9983990059 Order Date:
18 May 2015
 Thank you for fast solution
Stepan
Message 13 of 44
camilo.lemos
I sincerely apologize for this issue. I've contacted our systems team and they are working to get this resolved for you as soon as possible.
I'll keep you updated via this thread.
Camilo Lemos
Message 14 of 44
camilo.lemos
@Anonymous Our systems team needs more information to be able to process your request. Can you please describe the steps you are following before seeing this error? Were you able to fully install the program without errors? At what exact point does the error image pop up?
If you could share a screenshot of the error message, that would be very helpful.
Thank you,
Camilo Lemos
Message 15 of 44
Hi, instantly after double click on flow design start icon appers this message, Yes fully instal without errors
S pozdravem ?. Dokoupil
Stepan Dokoupil - +420 777 852 502
www.cgarch.cz
Message 16 of 44
camilo.lemos
@Anonymous Thank you for clarifying. Could you please attach an image of the error message? Sorry for the bother but it would be really helpful for our team to troubleshoot.
Camilo Lemos
Message 17 of 44
Hi, here is message...
S
Message 18 of 44
camilo.lemos
@Anonymous Perfect, thank you! I'll get back to you as soon as I have more info.
Camilo Lemos
Message 19 of 44
camilo.lemos
Hi @Anonymous, our systems team confirms they can see the download for Flow Design in your Autodesk Account, which means that you should be able to download it and install/activate from your account without any problems.
Can you please log in your Autodesk Account, download the program and try to use it?
Thank you,
Camilo Lemos
Message 20 of 44
Hy,
I have the same problem, the installation was ok, but when I try to excute flow, this message apperas and crack down:
Autodesk sign in
Connecting....
Have someone the solution?
