FlexSim Knowledge Base
Announcements, articles, and guides to help you take your simulations to the next level.
Process Flows for Two Types of Merge Controller
I'm attaching a user library and an example model that contains process flows for two types of merge controller. The main advantage of both of these is that the release strategy is consolidated into a single list pull query, so that you can have incredible flexibility in defining custom release strategies just by adjusting a single query. Several query examples are included and explained.
The DPClearingMergeController uses the standard merge controller mechanism that utilizes decision points and the merge controller's lane clear table to determine when slug lanes are clear for release. Alternatively, the FixedGapMergeController customizes lane release times for an optimal target gap between released slugs. This, combined with a good release strategy, can maximize total merge throughput.
Here's a view of the fixed gap merge control running. Notice how it tries to time the releases so the slugs line up pretty close on the take away lane (the target gap here is 3 feet).
And below is a screenshot of the fixed gap merge control process flow.
mergecontrollerprocessflows.zip
This model and library were created in 16.1.0.
Comments
I can't figure out how to join the process flow and the merge controller in version 19.
@William S3
Please post your issue or question as a new question.
