Announcements, articles, and guides to help you take your simulations to the next level.
Have you received this licensing error?
Operations error: 7581 Online return/repair request for the activation ID example.com01-ABCDE-FGHIJ-KLMNO-FSENT22.2 is not originated from the original client machine.
This error means that the licensing system did not recognize the the computer that requested the repair is the original computer where the license was initially activated.
This can happen when:
In this case the license cannot be returned, and it cannot be repaired. You will need to contact your local FlexSim representative to explain the situation.
As you work with your FlexSim rep, they will guide you in deleting your unreturnable/unrepairable fulfillment (license server, standalone), then after your FlexSim rep performs a license force-return, your license should be available again for a new activation.
