Have you received this licensing error?
Operations error: 7284 Cannot perform support actions on inactive fulfillment record FID_ ... (entire fulfillment ID listed)
You may encounter this error during an attempted license return or repair.
This error means that the fulfillment was already returned. A fulfillment is an activation of a license. Once that activation has been returned to the main license server, the fulfillment becomes inactive. It is meaningless to return or repair a fulfillment that has already been returned.
So, how do you have an inactive fulfillment still on your computer if it was supposedly returned? There are a couple of ways this can happen:
The point with this error is that FlexSim's main license server has a record that your fulfillment was already returned. The fulfillment you are trying to return or repair is inactive - no actions can be taken on it. The solution is to delete the fulfillment record from your PC:
