FlexSim Knowledge Base
Announcements, articles, and guides to help you take your simulations to the next level.
Operations error: 7174 Only deployed entitlement line item can be fulfilled.
Contributed by:
Have you received this licensing error?
An error occurred in the activation request
You may encounter this error if your license code is no longer valid or is in need of support. Here are some common scenarios where this might happen:
  • If this was a timed license that has expired, it is no longer viable and was likely obsoleted.
  • If the license was upgraded, you need to make sure you're using the latest version of the activation ID, as any older versions of the license code will not work once an upgrade of the same license has been used.
  • If the license model was changed from standalone to license-server (or vice-versa) you may be trying to use an old license that was replaced.
  • If your license was put into a support state and was not changed back.
If you are encountering this error, please start a new Private Question and include your activation ID. We'll be able to look up the specific situation for your license.
Or you can reach out to your local distributor for direct phone, email, or web support.
