FlexSim Knowledge Base
Announcements, articles, and guides to help you take your simulations to the next level.
Map Arrays- Map of Items
Contributed by:
Demonstrating Map Array Initialization and Population
(view in My Videos)
Overview
This FlexSim model showcases the use of a map array to efficiently manage, and reference items loaded onto a pallet. In FlexSim, a map is a specialized array structure that allows you to associate a unique key with a corresponding value. This setup enables easy retrieval of values using their associated keys, which is particularly useful for tracking and referencing simulation objects.
Model Implementation Details
In this model, the map array is initialized and attached to a pallet object. The model performs the following steps:
  1. Initialization: When the pallet is created, a new map array is initialized. This array will serve as the container for all key-value pairs related to items loaded onto the pallet.
  2. Population: As each item is loaded onto the pallet, the combiner records the item's name as the key in the map array. The corresponding value is set to the pointer or reference of the loaded item.
  3. Retrieval: At any point, if a reference to a specific item on the pallet is needed, the item's name can be used as the map key. The map array will return the pointer to the item, allowing for direct manipulation or querying of the item's properties.
Benefits and Use Cases
By utilizing a map array in this manner, the model enables efficient tracking and referencing of items on the pallet. This approach is particularly beneficial in scenarios where items may need to be accessed or modified individually after being loaded. For example, you can quickly locate an item by name and adjust its attributes or trigger specific actions without searching through a generic list or array.
The technique demonstrated in this model can be extended to other FlexSim objects and processes, making it a valuable pattern for organizing and managing complex simulations where object relationships need to be dynamic and easily accessible.
Conclusion
This FlexSim model provides a clear example of initializing and populating a map array on a pallet, with each item’s name used as a key and its pointer as the value. The model’s structure facilitates fast, reliable access to items by name, improving both the flexibility and maintainability of your simulation logic.
