You've installed, configured, and started your license server. FlexSim is installed and your client PCs are set to get a license from your license server. How can you tell if they're communicating and licensing properly?
You can check both the client PC and the license server to make sure that licensing is happening:
If your client PC is not getting licensed and/or your license server logs don't indicate communication with a client PC, check the license server troubleshooting steps.
