The instructions below are for Internet-connected license servers.
If your server cannot connect to the Internet or to FlexSim's main license server, try our offline/Manual XML license return instructions.
All steps below assume that you followed the installation instructions as described in our license server installation instructions, and that all FlexSim's license server files were extracted to the location C:\FlexSim_LMTOOLS. Throughout these instructions we will reference files inside that folder.
On your license server, run the flexsimserveractutil.exe program (C:\FlexSim_LMTOOLS\flexsimserveractutil\flexsimserveractutil.exe) by right-clicking and selecting Run as Administrator.
In the FlexSim ServerActUtil program, go to Tools > View License Rights.
Copy the Fulfillment ID for the Activation ID you are upgrading by highlighting the Fulfillment ID and pressing Ctrl+C.
When your license server returns a license over the the Internet, flexsimserveractutil.exe will communicate with the following FlexSim servers via HTTP (port 80) and HTTPS (port 443):
In the FlexSim ServerActUtil program, select Connect > Return.
Paste the Fulfillment ID into the field using Ctrl+V, and press the Return button.
After a few seconds and several status messages, you should receive an indication of success.
If you have any questions or problems, please search our Answers Community for possible solutions. There is a good chance someone else has already asked your question.
Still not finding what you're looking for? Submit a new question and we'll check it out. If you're including any confidential information, such as license codes, be sure to mark your question as private! You can also contact your local FlexSim distributor for live phone, web, or email help.
I followed the steps to return a FlexSim license from our server, but I’m getting the following error message:
ERROR: Unable to find fulfillment id...
The license is currently working fine, but the return process fails and doesn’t complete. I’m not sure if I’m missing a step or doing something incorrectly.
Has anyone encountered this issue before, or does anyone know what could be causing it?
Thanks!
I'm not familiar with license servers but here are a few personal ideas related to license activation:
1 - Sometimes just closing and restarting FlexSim fixes such issues.
2 - Is the internet connection working and not blocked by a firewall?
3 - Sometimes just waiting a few minutes and redoing it works.
4 - Is it a type of license that can be returned and transfered? Some licenses are locked to a computer.
