Often a client PC is used by a single user who should have access to change license settings.
This method saves licensing settings to the user’s Windows profile. In this manner licensing is saved on a per-user basis and should be completed in advance for each FlexSim user on this client PC.
In some situations it is better to license the PC once for any user who might log in. This can be the case for a university computer lab, for instance. If your situation would be better served by licensing the software one time for all users of the PC, please check out our guide to license a mult-user client PC.
To license an individual Windows user, do the following while logged into Windows as that user:
If your FlexSim licenses/seats are spread across multiple license servers, you can configure your client software to try to pull a license from any of your multiple license servers. Simply enter all available license server options, separated using a semi-colon, like this:
[email protected];[email protected];[email protected]
Here is an example image:
The software will attempt to contact each license server in turn until it obtains a seat or has attempted all license servers and failed.
In the example above, lic.server.one and lic.server.two are fully qualified domain names to properly configured license servers, with lmgrd serving on ports 26914 and 27001 respectively. You could also use an IP address instead of a FQDN.
Check out the next article to learn how to verify that your client PC is licensed, and what to do if it isn't: License Server - Verify client PC licensing.
