FlexSim Knowledge Base
Announcements, articles, and guides to help you take your simulations to the next level.
Generating a Correct “Time to First Event” Distribution
When modeling arrivals or failures, it is common to reuse the inter-arrival time distribution as the one used to sample the time to first event.
Except for memoryless processes (e.g., negative exponential), this is not statistically correct and introduces a left-bias where early events occur sooner than they should.
The user command in the attached library generates a statistically valid time-to-first-event distribution from a definition of inter-arrival times.
Problem Being Addressed
  • Inter-arrival distributions describe time between events, not time to the first event
  • Reusing the same distribution biases early arrivals/failures
  • Bias is most visible in:
    • Short simulation runs
    • Models without warm-up periods
    • Models initialized with work-in-progress
What the Command Does
The command generates a sample set for time to first event using inter-arrival data provided as:
  • A FlexScript distribution expression (string)
  • An array of inter-arrival samples
  • An existing Empirical Distribution object
The process:
  1. Generates a timeline of events using inter-arrival samples
  2. Selects random observation points along the timeline
  3. Measures time to the next event
  4. Stores these values in a new Empirical Distribution object
  5. Runs the Fit function to suggest a best-fit distribution and parameters
Output
  • A new Empirical Distribution representing time to first event
  • A fitted distribution expression (name + parameters) suitable for direct use
  • Option to sample empirically or via the fitted distribution
Typical Use Cases
  • Time to first failure fields
  • Arrival processes where warm-up is undesirable
  • Short-term forecasting models
  • Models requiring statistically defensible early-run behavior
Why Use This Approach
  • Avoids bias introduced by reusing inter-arrival distributions
  • Produces statistically defensible results
  • Reduces reliance on warm-up periods
  • Especially beneficial when early statistics matter
How to Use the Command
Loading the attached user library will auto-install the required user commands. The command createTTFeventDist creates an Empirical Distribution that represents the time to first event, derived from an inter-arrival time definition.
Parameters
  • P1 (string)
    Name of the new Empirical Distribution object to create.
  • P2 (overloaded)
    Definition of the inter-arrival times. One of:
    • The name of an existing Empirical Distribution object
  • P3 (optional integer)
    Number of time-to-first-event samples to generate and store in the new Empirical Distribution.
    (Default is suitable for most use cases.)
  • P4 (optional integer)
    Number of inter-arrival samples used to construct the event timeline.
    (Larger values improve stability at the cost of run time.)
Example: Time to First Failure from a Weibull Inter-Arrival Process
Assume failures follow a Weibull inter-arrival distribution, but the model starts at an arbitrary point in time and does not use a warm-up period.
Instead of reusing the Weibull distribution directly for the first failure, generate a statistically correct time-to-first-failure distribution.  Open a script window and run this command with the example parameters:
createTTFeventDist(
	"FirstFailureDist",
	"weibull(0,120, 1.8)",
	5000,
	100000);
This command:
  • Generates a large inter-arrival timeline from 100000 samples of  the Weibull distribution
  • Samples valid times to the next failure
  • Creates an Empirical Distribution named FirstFailureDist
  • Fits a theoretical distribution and reports suggested parameters (eg.  beta(-0.08, 356.54, 1.20, 4.89))
Using the Result in the Model
You can now use the generated distribution in either of the following ways:
  • Use the fitted distribution expression
    Copy the suggested distribution name and parameters into a
    Time to First Failure or arrival field.
  • Reference the Empirical Distribution directly
    Sample from the Empirical object where a time-to-first-event value is required, choosing either:
    • Fitted distribution sampling, or
    • Empirical data sampling
Both approaches ensure the first event is statistically consistent with the defined inter-arrival process.
