FloWorks 25.1.0 is now available (15 April). This version of FloWorks is intended for use with FlexSim 2025 Update 1.
- If you are using FloWorks with FlexSim 2024, please update to FloWorks version 24.0.8.
- If you are using FloWorks with FlexSim 2024 Update 2, please update to FloWorks version 24.2.2.
- If you are using FloWorks with FlexSim 2025 (LTS), please update to FloWorks version 25.0.2.
All versions can be found in the Downloads section of your FlexSim account on the 3rd party modules tab. Please do not hesitate to report any bugs, usability improvements and feature requests to [email protected].
About FloWorks
FloWorks is a 3rd party module developed and maintained by Talumis BV (talumis.com). It provides faster and more accurate modelling and calculation of fluid systems than the default FlexSim fluid library. It is especially useful within the oil, gas, and bulk industry both for production and supply chain optimization. This module requires a FloWorks license with active maintenance.
For any questions, please email [email protected].
Release notes
View the full release notes in the online documentation.
FloWorks 25.1.0 (15 April 2025)
FloWorks 25.0.2 (15 April 2025)
- All changes in version 24.0.8.
- Improvement: Updated FloWorks tutorials
- Bug fix: merged duplicate "Modules" folders in offline User Manual
FloWorks 25.0.1 (21 January 2025)
- FloWorks was not loading correctly in FlexSim 25.0.2.
FlexSim Compatibility Note:
This release of FloWorks is for FlexSim 25.0.2 and higher versions. For FlexSim 25.0.0 and FlexSim 25.0.1, please use FloWorks 25.0.0 or upgrade your FlexSim version.
FloWorks 25.0.0 (19 December 2024)
- Improvement: FlowConveyor can be reversed.
- All bug fixes in FloWorks 24.2.1 below.
FloWorks 24.2.2 (15 April 2025)
- All changes in version v24.0.8.
FloWorks 24.2.1 (19 December 2024)
- Improvement: Made Disconnect Flow Objects properties more clear.
- All bug fixes in FloWorks 24.0.6 below.
FloWorks 24.2.0 (6 August 2024)
- Bug fix: removed flicker due to unnecessary repaint in ApplyImpactFactor QuickProperties panel.
- All bug fixes in FloWorks 24.0.4 below.
FloWorks 24.1.1 (6 August 2024)
FloWorks 24.1.0 (17 April 2024)
- Feature: new "Apply Impact Factor" activity in ProcessFlow.
- Feature: new "Connect Flow Objects" and "Disconnect Flow Objects" activities in ProcessFlow.
- All bug fixes in FloWorks 24.0.3 below.
FloWorks 24.0.8 (15 April 2025)
- Improvement: Setting
.content of multi-product tank will now increase or decrease layers as if there was inflow or outflow. - Improvement: Internal build tools updated to ensure for example FloWorks FlexScript API documentation is always updated and Table of Contents of online and offline manual are synchronized.
- Improvement: Installer no longer contains the build number in the filename (e.g. FloWorks_25.0.1.msi instead of FloWorks_25.0.1.2348721.msi).
- Improvement: More actions create a module dependency, such as creating a FloWorks object through
Object.create. - Improvement: Start joint of a flow pipe can now be dragged too; also added controls on the segments to drag the whole pipe in z-direction.
- Improvement: Impact ID in functions like
FlowObject.stop() are now Variant instead of treenode.
Backwards Compatibility Note:
The following may change the way updated models behave.
- Improvement: Setting trigger interval will now cancel and recalculate already scheduled trigger. See the extended note at Set Flow Trigger - "Interval (each)".
FloWorks 24.0.7 (21 January 2025)
- FloWorks was not loading correctly in FlexSim 24.0.8.
This release of FloWorks is for FlexSim 24.0.8 and higher versions. For FlexSim 24.0.7 and earlier, please use FloWorks 24.0.6 or upgrade your FlexSim version.
FloWorks 24.0.6 (19 December 2024)
- Bug fix: Flow Mixer stops with error when pulling product from an invalid port.
- Bug fix: Reactor vessel shape was not correctly upgraded to 24.0 from older versions.
- Bug fix: FlowConveyor content visualization was incorrect.
- Bug fix: SharedResource showed exception and didn't work correctly.
- Improvement: Impact events can be resumed with a
Variant id identifier instead of treenode eventObject. - Improvement: Fixed many incorrect tooltips in the FloWorks ProcessFlow activities.
FloWorks 24.0.5 (27 August 2024)
- Bug fix: Version 24.0.4 installer contained an incorrect module (.t) file
- Bug fix: Removed ProcessFlow activities which are only available from 24.1 from the drag/drop library
FloWorks 24.0.4 (6 August 2024)
- Bug fix: FlowToItem was not behaving correctly when an item buffer was used.
- Bug fix: Fixed a timing issue when FlowToItem got starved while an item was being released.
- Bug fix: Fixed some rounding issues in event scheduling.
- Bug fix: Fixed Quick Properties product combo when product has been deleted.
- Bug fix: Missing states 19 and 20 added to state profile.
- Bug fix: Fixed several issues in FlowConveyor visualization.
- Bug fix: Invalid curved FlowConveyor animation fixed.
- Bug fix: Invalid initial content for Segmented Pipe fixed.
- Bug fix: "FlowConveyor content changes are not allowed" error (and subsequent exception) fixed.
- Improvment: Curved conveyor now also supports FlowConveyor length property.
- Improvement: Tank label hidden in FlowItems (FlowVessel and FlowTruck).
- Improvement: Cleaned up the variables in the FlowItems' model tree.
- Improvement: Tank size/position and max content changed for FlowTruck, also as FlowTaskExecuter.
- Improvement: Slight optimization in preventing unnecessary FlowControl events.
- Improvement: Added
SetMaxContent for FlowToItem and improved handling for Flow Tanks.
FloWorks 24.0.3 (17 April 2024)
- QuickProperties behavior improved.
- Fixed invalid manual references.
- Fixed missing code completion documentation.
FloWorks 24.0.2 (6 March 2024)
- Made activity path references in warning message more clear.
- Restore missing Flow Trigger Process Flow activities to the library.
- Fixed Tank level indicator settings for some tank shapes.
- Add Accumulating checkbox to the Conveyor properties.
FloWorks 24.0.1 (5 February 2024)
- Added vertical splitter to Mixer recipe editor and other small layout improvements.
- Fixed missing icons in statistics panel pin menus.
- Flow Polygon Tank property panels fixed and documentation updated.
- Added "Fill Sideways" property for Flow Polygon Tank.
IsMultiProduct setting on Flow Tank is now a proper property.- Renamed Flow Tank shapes from Cylindric and Rectangular to Tank and Container, respectively.
- Fixed "Copy Production Plan" button in Flow To Item properties.
- Some objects were not correctly reset.
ItemToFlow statistics were accessible through .output instead of .input.
Breaking changes:
- Deprecated the
input.triggerAmount, input.triggerInterval, output.triggerAmount, and output.triggerInterval properties. FlowObject.stats.input and FlowObject.stats.output now return a Tracked Variable.- Cylindric level indicator now expects size of bounding box instead of center and radius. The update script will try to convert these for you.
FloWorks 24.0.0 (14 January 2024)
- All bug fixes in FloWorks 23.0.5 below.
- Improved warning and error messages throughout
- Fixed rounding issue in Mass Flow Conveyor
