FlexSim Knowledge Base
Announcements, articles, and guides to help you take your simulations to the next level.
FloWorks 2023 Update 2 released
Contributed by:
FloWorks 23.2.0 is now available (10 August 2023). This version of FloWorks is intended for use with FlexSim 2023 Update 2.
If you are using FloWorks with FlexSim 2023 (LTS), please use FloWorks version 23.0.3 (LTS). If you are using FloWorks with FlexSim 2023 Update 1, please use FloWorks version 23.1.1.
All versions can be found in the Downloads section of your FlexSim account on the 3rd party modules tab. Please do not hesitate to report any bugs, usability improvements and feature requests to [email protected].
About FloWorks
FloWorks is a 3rd party module developed and maintained by Talumis BV ( talumis.com). It provides faster and more accurate modelling and calculation of fluid systems than the default FlexSim fluid library. It is especially useful within the oil, gas, and bulk industry both for production and supply chain optimization. This module requires a FloWorks license with active maintenance.
For any questions, please email [email protected].
Release notes
View the full release notes in the online documentation.
FloWorks 23.2.0
  • Updated FloWorks for FlexSim 2023 Update 2.
FloWorks 23.1.1
FloWorks 23.1.0 (12 April 2023)
  • Segmented Pipe: removed virtual content and fixed properties
  • Changed default content of flow tanks and mixer from 50,000 to 1,000.
  • All bug fixes in FloWorks 23.0.2 below.
FloWorks 23.0.3
  • Bug fix: Module dependency shows invalid module version number
  • All bug fixes in FloWorks 22.0.7 below.
FloWorks 23.0.2 (12 April 2023)
  • Moved flow control to toolbox
  • Support time series, level triggered event and workability in Tools.create and Tools.get
  • Added context menu option to disable time series in toolbox
  • Added dot syntax to create flow controls, get the default flow control, and request recalculation of a flow control's network
  • All bug fixes in FloWorks 22.0.6 below.
FloWorks 22.0.7
  • Bug fix: Multi-product FlowTank blocks simulation when layer is small but nonzero, due to rounding error.
FloWorks 22.0.6 (12 April 2023)
  • Bug fix: Loading Arm processing time defaults to 10.
  • Bug fix: fixed length³ to volume conversion for models in non-metric units
  • Bug fix: fixed error message "FlowConveyor content changes are not allowed"
  • Bug fix: flow conveyor density calculation was incorrect with non-metric units
  • Bug fix: icon grid was not filtering correctly when A-connecting
  • Bug fix: flow conveyor properties panel fixed
  • Bug fix: added vertices editor to polygon flow tank quick properties
  • Bug fix: after the first vessel, vessels were positioned incorrectly in the loading point
  • Bug fix: quick properties now shows "Max. rate" for Loading Arm and "Max. inflow" for Flow Sink.
  • Bug fix: removed duplicate Input / Output / Content change events from event selection list
  • Bug fix: corrected input / output in on change event at end of warmup
  • Bug fix: on empty and on full event would sometimes fire twice
