FlexSim Knowledge Base
Announcements, articles, and guides to help you take your simulations to the next level.
FloWorks 2022 Update 2 available
Contributed by:
FloWorks 22.2.0 is now available (31 August 2022). This version of FloWorks is intended for use with FlexSim 2022 Update 2.
If you are using FloWorks with FlexSim 2022 Update 1, please use FloWorks version 22.1.1. If you are using FlexSim 2022 (LTS) please use FloWorks version 22.0.2.
All versions can be found in the Downloads section of your FlexSim account on the 3rd party modules tab. Please do not hesitate to report any bugs, usability improvements and feature requests to [email protected].
About FloWorks
FloWorks is a 3rd party module developed and maintained by Talumis BV ( talumis.com). It provides faster and more accurate modelling and calculation of fluid systems than the default FlexSim fluid library. It is especially useful within the oil, gas, and bulk industry both for production and supply chain optimization. This module requires a FloWorks license with active maintenance.
For any questions, please email [email protected].
Release notes
FloWorks 22.2.0
  • New: Added a Flow Gauge object to measure and visualize the flow through a connection
  • New: Added a Time Series object to the Toolbox as a source of daily, weekly or monthly changing values
  • Improvement: Added several alternative shapes for Flow Source such as Plant and Well
  • Improvement: Level Triggered Event now has an OnTriggerFired event that ProcessFlow can await
  • Bug fix: Some additional issues with incorrect scaling when not using meters
  • Bug fix: Flow tank level triggers issue with multiple levels (not) firing
  • All bug fixes in FloWorks 22.0.2 below.
Backwards Compatibility Note:
The following change may change the way updated models behave.
  • Flow Impact Event has been deprecated and may be removed in the future. Picklist options for applying impact factors have been added to FlexSim's own MTBF/MTTR and Timetable. As an improvement, the same picklist options are also available in Down Behaviors.
FloWorks 22.1.1
FloWorks 22.1.0 (12 May 2022)
FloWorks 22.0.2
  • Bug fix: FlowMixer.loadRecipe can handle re-ordered product tables
  • Bug fix: Statistics are now correctly initialized for flow tanks created during run.
FloWorks 22.0.1 (12 May 2022)
  • Added support for Object Property Tables
  • Bug fix: incorrect MassFlowConveyor content
  • Bug fix: LoadingPoint issue with not-released positions (and status)
  • Bug fix: Object created at incorrect scale when not using meters
Comments
The links on "Flow Gauge" and "Time Series" don't appear to work, and instead just give the error message "Page Not Found".
@Harald Emsbroek @Mischa Spelt could you please update the 2 broken links reported by Jeremy ?
