FlexSim Knowledge Base
Announcements, articles, and guides to help you take your simulations to the next level.
FloWorks 2022 available
Contributed by:
FloWorks 22.0.0 is now available (21 December 2021). This version of FloWorks is intended for use with FlexSim 2022.
If you are using FloWorks with FlexSim 2021 (LTS) you can upgrade to FloWorks version 21.0.5. If you are using FlexSim 2021 Update 2, you can upgrade to FloWorks version 21.2.1.
All versions can be found in the Downloads section of your FlexSim account on the 3rd party modules tab. Please do not hesitate to report any bugs, usability improvements and feature requests to [email protected].
About FloWorks
FloWorks is a 3rd party module developed and maintained by Talumis BV ( talumis.com). It provides faster and more accurate modelling and calculation of fluid systems than the default FlexSim fluid library. It is especially useful within the oil, gas, and bulk industry both for production and supply chain optimization. This module requires a FloWorks license with active maintenance.
For any questions, please email [email protected].
Release notes
FloWorks 22.0.0
FloWorks 21.2.1
  • New: (segmented) flow pipe has option to suppress "Product Out Changed" event from product 0 to initial product.
  • Bug fix: changed wording in tutorial 2 so it can be completed again.
  • Bug fix: FlowVessel and FlowTruck flow item issues fixed
  • All bug fixes in FloWorks 21.0.5 below.
Backwards Compatibility Note:
The following change may change the way updated models behave.
  • (Segmented) flow pipe no longer fires the "Product Out Changed" event for zero-width layers (e.g. as created by the Pass Product Downstream trigger).
FloWorks 21.0.5
  • Bug fix: when impact event ends, when no recalculation is necessary, the flow object state is now re-determined.
  • Bug fix: SetFlowConveyorSpeed function fixed.
  • Bug fixes to solver: incorrect flow with full tank-type objects.
  • Bug fix: FlowConveyor approximately full/empty issues fixed.
  • Bug fix: FlowConveyor settings (width, speed, ...) could not be set in quick properties.
