FlexSim Knowledge Base
Announcements, articles, and guides to help you take your simulations to the next level.
FlexSim Feature Limitations by License Type
Contributed by:
This table is meant as a reference and guideline. While we strive to maintain this list regularly, it may be out of date at any given time. If an advertised feature of FlexSim is not listed here, it is generally not subject to limitations by license type.
The Express license type is FlexSim's default, unlicensed state. Downloading and installing FlexSim to a new computer, it will be in Express mode. The other license types require you to obtain a license and apply it to the software. Please refer to FlexSim's End User License Agreement (EULA) for details on allowed uses, restrictions, and other considerations. If you wish to test a particular license type, please contact your local distributor to request a test license.
Please Note: Runtime seats are no longer available for new purchase or renewal but are referenced in this table to support those Runtime licenses still outstanding.
Please Note: Autodesk sells a node-locked subscription license. This is the same as Enterprise in the table below, with some restrictions on moving the license. Please see our article Node-locked license vs Transferable license.
  Express Runtime Student Educational Enterprise
Use Cases (see EULA) Testing, evaluation, and model viewer only. Run only (no model building). Educational use only. Educational use only. See EULA.
Open, Run, Save
open and run any size model
open and save models in XML format
unlocked random streams
compile models built with C++ (optional, requires Visual Studio)
save model size limitations model size must be under limitations none model size must be under limitations none none
experimenter
OptQuest optimizer   with OptQuest add-on license up to 10 optimization variables with OptQuest add-on license with OptQuest add-on license
webserver (requires separate download)
Model Building
model building features available
no ability to add objects or activities, but any objects and activities used by existing models are editable
create objects and activities
object creation limit 30   100 none none
process flow activity creation limit 35   250 none none
execute FlexScript in script console
tree view
Tool Box
Add Tools
no ability to add tools, but all tools used by existing models are editable
FlowItem Bin
Global Tables
Time Tables
MTBF/MTTR
Down Behavior
Dashboards
Groups
Process Flow (all options)
Global List (all options)
Statistics - Statistics Collector
Statistics - Milestone Collector
Statistics - Calculated Table
Statistics - Experimenter
Statistics - Tracked Variable
FlowItem (all options)
Modeling Logic (all options)
Visual - Model Floor
Visual - Model Background
Visual - Video Recorder
Visual - Fly Path
Connectivity - Database Connector
Connectivity - Excel Import/Export
Connectivity - Visio Import
Connectivity - Emulation (Modbus and OPC DA connections only. Other connection types require an Emulation license.)
Comments
@Ben Wilson
It's great!. I need it as a table like this.
Could you upload it as pdf file?
Hi @Seung Yong Seo,
Updating and hosting a hard-copy of the table defeats the purpose of having a "living document" that the dev team or others update as necessary, but here are some options you can use to create your own hard-copy from the table above:
The best course of action, rather than downloading, archiving, and sharing a hard-copy of this page, is to just send the link to those who might be interested. That way they are always viewing the most up-to-date information, not an out-dated PDF, image, etc.
@Ben Wilson This is very helpful. How can I "Like" this article? I can't find the Thumbs up?
Image.pngThanks @david.chan, I hope it will be helpful for everyone.
You can show your support or disapproval for questions, answers, ideas, and articles using the up and down arrows near the top of the post, under the user's gravatar image. See the screen capture to the right:
You can also up- or down-vote comments using the arrows below the comment body.
Hi Ben,
maybe you need to add one row for clarification purpose: A client asked me, if the express version is allowed to be used as a model viewer for commercial purpose. They want to use it to:
1. Share models to only "view" them as they are and
2. Use the Express version for model runs within its technical limitations, incl. changing parameters.
So we might want to add "commercial use" as a row?
Ralf
Hi @Ben_WilsonADSK , this post need to be updated to include node-locked license also
@arunTTT2P , Thanks for the suggestion.
In terms of the table of FlexSim's in-software features, the license sold by Autodesk as a subscription node-locked license is an Enterprise license. I agree it's worth pointing out what a node-locked license is, so I added another "please note" to point people to our article about node-locked vs transferrable licenses.
