FlexSim Knowledge Base
Announcements, articles, and guides to help you take your simulations to the next level.
FlexSim 2019 Update 1 Available
Contributed by:
FlexSim 2019 Update 1 is available.
If you have bug reports or other feedback on the software, please email [email protected] or create a new idea in the Development space.
Release Notes
  • Added a new graphical interface to the Calculated Table for building queries.
  • Updated the UI for editing rack dimensions.
  • Added more options for customizing people visuals.
  • Moved operator shape options from the Operator tab to Quick Properties.
  • Improved edit modes by using right-click to cancel the current action instead of immediately exiting the mode.
  • Added global preferences for process flow and dashboard library options.
  • Added the FlexScript API reference to the user manual and made it accessible outside of FlexSim.
  • Added toolbar support for adding multiple model background drawings.
  • Adjusted how the floor Z and grid Z settings work to improve multi-floor modeling.
  • Updated the table view to show more helpful information for certain data types.
  • Added support for pointer data in bundles.
  • Added a pointer type to tracked variables.
  • Added support for the NULLIF SQL keyword.
  • Added support for linking combo boxes to nodes with pointer data.
  • Improved the gantt chart.
  • Updated how tree files are saved to improve saving certain datatypes.
  • Updated pulling from lists to throw an exception when passing a bad query.
  • Fixed a bug with the normal map lighting calculation.
  • Fixed an issue with the picking focus when using drawsurrogate within a drawsurrogate object.
  • Fixed exceptions on an array table that doesn't have column header information.
  • Fixed an issue related to moving items that had not been released.
Backwards Compatibility Note: the following changes may slightly change the way updated models behave.
  • Updated the internal structure of the Rack object's variables.
  • Removed the rackgetcontenttable() command.
  • Removed support for running the simulation from a loaded state file.
Process Flow
  • Added an option to the container to center its title when the contents are hidden.
  • Added a limit to the number of activity panels displayed in quick properties.
  • Added a Milestone activity.
People
  • Added a Healthcare environment option.
  • Added an Elevator Bank object.
  • Added a Prop object and more options for object visuals.
  • Added tables that automatically collect statistics for people models.
  • Added people chart templates.
  • Added a People Settings object to the toolbox for people models.
  • Improved the names of people created with the Create Person activity.
AGV
  • Updated the distancetotravel() calculation to work with moving AGVs.
A*
  • Added support for multiple grids.
  • Adjusted how conditions are defined to improve performance.
