FlexSim Knowledge Base
Announcements, articles, and guides to help you take your simulations to the next level.
FlexSim 2018 Update 2 Available
Contributed by:
FlexSim 2018 Update 2 is available.
If you have bug reports or other feedback on the software, please email [email protected] or create a new idea in the Development space.
Release Notes
  • Added an interface for running experiments and optimizations on the cloud.
  • Added a mechanism for adding new charts as experimenter performance measures.
  • Added a Sankey Diagram to the dashboard charts.
  • Added a Milestone Collector statistics tool and chart templates.
  • Added a way to customize how objects draw their 3D shape meshes.
  • Added {} syntax to specify FlexScript expressions in SQL queries.
  • Added a Down Behavior tool that can be used by Time Tables and MTBF MTTR objects.
  • Added a message() method to the Object class to replace sendmessage() and senddelayedmessage().
  • Added a varchar bundle field type for variable-length strings.
  • Added status bar updates to the table view.
  • Updated the bar and pie charts with more options and data formats.
  • Added duration settings to the gantt chart.
  • Added new task sequence classes to the FlexScript API.
  • Added a getCategoryName() method to the TrackedVariable class.
  • Added getEntryFromValue() and reevaluateBackOrders() methods to the List class.
  • Added padStart() and padEnd() methods to the string class.
  • Added an option to sort back orders independent of entries when reevaluating back orders.
  • Added an option to configure a list to always leave its entries on the list.
  • Added events to the Statistics Collector.
  • Added options for sorting rows in statistics collectors.
  • Added dot syntax label access to List.BackOrder.
  • Added a backOrder keyword that is available in a list back order queue strategy.
  • Added a new overload to List.pull() that takes both an array and a query.
  • Updated user library functionality to better handle conveyor types and containers.
  • Updated Move into Highlighted code to preserve global position and rotation.
  • Improved sampler options in various places.
  • Improved drop-down options with label values in several places.
  • Updated the Ctrl+W keyboard shortcut so it correctly closes the window that has keyboard focus.
  • Updated the query() command to re-throw exceptions.
  • Fixed a bug with updating bundle indexes when using certain commands.
  • Fixed a performance bug with pasting into bundle tables.
  • Fixed a window docking bug.
  • Fixed a bug with the robot not drawing collision spheres or its stopped indicator.
Backwards Compatibility Note: the following changes may slightly change the way updated models behave.
  • Changed Variant math operations on non-numbers to throw exceptions.
  • Updated the Source to automatically attach task executer flowitems to the DefaultNavigator.
  • Updated dumpquery() to use bundle varchar fields.
  • Fixed an issue with the Z-axis being inverted for screen-locked shapes in perspective 3D views.
Process Flow
  • Added stop() and resume() methods to the Token class.
  • Updated global shared assets so they now have a separate global block instance.
  • Updated Edit Mode so you can no longer move activities when it is off.
  • Added a check box to quick properties to turn off all trace histories.
  • Updated Wait for Event to handle listening to arrays of objects.
  • Updated Pull from List so you can use it with a Resource shared asset.
  • Updated the Resource so you can point it at a global List or a List shared asset.
  • Added a way to sample shared assets in certain fields.
  • Updated the naming convention for Resource object copies.
  • Added an error message when trying to rename a shared asset the same name as another.
  • Improved the performance of the Wait for Event activity.
People
  • Updated the multi-location to allow people to enter without an available sub-location.
Conveyor
  • Added a max count slug building property to the conveyor type.
  • Added a catch condition to the power and free functionality to customize whether a given dog will actually catch an item.
  • Added the capability to reverse conveyors under certain conditions.
  • Changed the roller skew kinematics to be based on item travel distance instead of time.
  • Changed the conveyor's belt repeat distance to sync to the adjusted dog interval.
  • Fixed a bug with decision points snapping to grid when added with a conveyor from a user library.
AGV
  • Updated path transfers to prioritize their requests.
  • Fixed an issue with accumulating path allocations causing AGVs to get stuck.
  • Fixed various issues with AGVs having different deceleration values.
  • Improvements to AGV proximity detection on accumulating paths.
Emulation
  • Fixed Modbus polling for changes.
  • Fixed the Modbus panels in the Variable shared asset so they show the associated object now.
