FlexSim Knowledge Base
Announcements, articles, and guides to help you take your simulations to the next level.
FlexSim 2018 Update 1 Available
Contributed by:
FlexSim 2018 Update 1 is available.
If you have bug reports or other feedback on the software, please email [email protected] or create a new idea in the Development space.
Release Notes
  • Added a Database Connector tool and Database FlexScript API.
  • Updated the Emulation module and added it to the toolbox.
  • Updated object triggers to be dynamically added and executed to improve performance and flexibility.
  • Added an option to store StatisticsCollector bundle data on the hard drive.
  • Added a global preference for date and time formats, which will default to the system's locale settings.
  • Updated the stick() command to be able to get information about the VR headset by passing -1 for the stick number.
  • Added a Box Plot chart type.
  • Added a visual Walls object, which can be connected to A* as a member.
  • Added an option to reverse rows on a gantt chart.
  • Updated how the gantt chart handles colors.
  • Added a time window option to several charts.
  • Improved axis title options on several charts.
  • Added a y-axis range option to the time plot.
  • Output, system, and compiler consoles now wrap lines.
  • Added a binoculars button to the bottom of properties windows.
  • Fixed a bug with using local variable "a" within FlexScript lambda commands, such as findmatch().
Backwards Compatibility Note: the following changes may slightly change the way updated models behave.
  • Removed FlowNode, Reservoir, WatchList, and other unused library class objects.
  • Changed transportincomplete() to be more fail-safe so that it only affects the object when called correctly.
  • Fixed an issue with the Rack sometimes receiving items out of order when the upstream object is using a transport.
Process Flow
  • Added a Variable shared asset.
  • Updated the Event-Triggered Source and Wait for Event activities to be able to match values.
People
  • Added a Waiting Line object and a Wait in Line activity.
AGV
  • Fixed a bug with preempting an AGV during a pre-arrival event.
  • Improved AGV proximity detection for stop-space-based accumulation.
  • Fixed an issue with reversing direction on accumulating paths.
A*
  • Added a routing mode for traveling at right angles only.
  • Added an option for stopping and turning when changing directions.
  • Added an option for routing by travel time.
  • Improved the usability of creating and editing barriers and dividers.
  • Added an option for snapping dividers between grid points.
  • Fixed some visual issues with various components.
  • Fixed a bug with distancetotravel().
  • Improved the accuracy of the calculation of which grid points are affected by dividers.
  • The mechanism for recovering from deadlock has been changed.
  • The path costing system was slightly changed to allow for travel-time-based routing.
Comments
@phil.bobo
I found a problem like a bug attached captured.
flexsim 2018 update 1
vs
flexsim 2018.0.4
The issue is flexsim update 1 has not the the fields of Change Rule and Change Value in the statistics collector UI.
Any other way?
Thanks.
This is a bug. It only occurs if you are sampling a group. For now, you can add the objects to the stats collector individually, and it should give you the correct view.
