So you were trying to record a video and the Video Recorder crashed. Here is a step by step guide on how to debug the video recorder:
In some older versions of FlexSim (2022 and older), if there is a stop time in your model that occurs during the model recording time, the video recorder will stop indefinitely at that time. Try removing any stop times that occur during the recording.
This is the most common problem we see as to why the video recorder is not working. To start debugging this issue, check what graphics card FlexSim is using. If you open a model then go to Help->About FlexSim from the top toolbar, you will open this screen:
The highlighted text that starts with OpenGL tell you what graphics card FlexSim is using. Now you might need to do a little research to find what graphic driver that card is using and then update it, but we've found in most cases updating the graphics card driver fixes video recorder issues. There's an article here the explains more on how to update your graphics driver (it's a very helpful read that also deals with some special cases on certain graphics cards). Make sure you're downloading either directly from the makers website or for your specific computer type, your computer will not be able to tell you if they're out of date.
If you make a very simple model (Source -> Queue -> Processor -> Sink), can you record it without issue? If you can then at least you know your video recorder can work, it is just having a issue with running a bigger model. If this is the case you might be running out of VRAM or the bigger model is taking so long to run that an outside manager is forcing it to close. If that is the case, here are some things to try:
There may be some corrupted data stuck in your recorder. It's an easy fix, you just need to delete your video recorder from toolbox and then re-add it:
In a few of the older versions (2019.1 and older), temporary nodes from previous recordings caused the Video Recorder object to crash. To fix it all you need to do is clear the nodes
Open your model, execute the following script, and then re-save your model:
Model.find("Tools/VideoRecorder>variables/active").subnodes.clear();
If none of the above steps worked you can create and check debug log files, check the filepath, check various computer settings, and see the VRAM allocations to start solving the problem.
You can use Window's "dxdiag" tool to see how much VRAM your graphics card has:
If you tried all of these suggestions and nothing worked, feel free to ask a question on the Q&A board and we can work to see if we can find a different solution for you!
I am sorry to let you know, that most picture uploads didn’t make into your revision of this article. There are mostly blank pictures with blue backgrounded question marks. You find attached the end of the article showing uploaded files. There is only one.
regards Joerg
